When boot from battery, then plug in 5V cable, the actual charging current can't reach the preset charging current. It is because the HEADROOM_ADJ is not correctly set. Please use attached mx28_chargingcurrent_limit_bootfrombattery.patch.
Grace
Hi Grace,
any reason why this patch hasn't commited to the imx_2.6.35_maintain branch?
