Q&A: Is it an error about IOMUXC_GPR2 register in the reference manual?
Document created by Yixing Kong Employee on Sep 23, 2013
Version 1Show Document
  • View in full screen mode
Question:
The description of the IOMUXC_GPR2 register is wrong. It contains exactly the same description as the LDB_CTRL register. The bits in the LDB_CTRL register work as advertised opposed to the GPR2 register.
Answer:
This is intentional. The LDB_CTRL description in the RM says "The register is implemented in the IOMUX Controller block (IOMUXC), as the register IOMUXC_GPR2.". And you will notice the two registers have the same address.
2 people found this helpful
    Outcomes
