Patch for Dual Video Function in i.MX53 Android (Broken Since R10.3.1)
Document created by MaxTsai Employee on May 8, 2013Last modified by ebiz_ws_prod on Dec 13, 2017
Version 6Show Document
  • View in full screen mode
The refine to TV mode of R10.3.1 causes dual video function fail.
The attached patch recovers dual video function.
Attached dual_video.patch only work for RGB output (HDMI support).
For legacy TVout (YUV output), the extra patch is necessary, see the attached "".
Refer to Dual video with single UI on i.MX53 SMD with Android R10.4  for setup.
Original Attachment has been moved to:
