You'll need this Tips for your brand new CodeWarrior TAP! (ColdFire)
Freescale CodeWarrior Tap Tip
If you mix the great new TAP kit for CodeWarrior with the right Tip, the possibilities of debugging your devices become bigger and more powerful.
In this occasion I will show you one more removable probe Tip: the CWH-CTP-BDM-YE, meant for ColdFire processors connects your ColdFire microprocessor/microcontroller target system’s BDM port to the CodeWarrior TAP base unit’s 30-pin target connector.
The compatibility of this Tip and the CodeWarrior TAP CWH-CTP-BASE-HE base unit empowers your creations and helps you lowering costs. Note this Tip is not included within the TAP kit. Check out the cool features:
Features
  • Removable probe tip
  • Low cost and economical to order several spares
  • Allows base unit to work with several different target types
System Requirements
No ratings
Version history
Last update:
‎09-21-2012 05:08 PM
Updated by:
