Description | Implements a wrapper to the Percepio SE FreeRTOS+Trace library. See this blog post. |
Component | PercepioTrace.PEupd |
Dependencies | FreeRTOSTrace, FreeRTOS v1.095 or later |
(c) Copyright Percepio AB, 2012
http : www.percepio.se
mail : info@percepio.com
Processor Expert port: Erich Styger, 2012
* Terms of Use
* This software is copyright Percepio AB. The recorder library is free for
* use together with Percepio products. You may distribute the recorder library
* in its original form, including modifications in trcPort.c and trcPort.h
* given that these modification are clearly marked as your own modifications
* and documented in the initial comment section of these source files.
* This software is the intellectual property of Percepio AB and may not be
* sold or in other ways commercially redistributed without explicit written
* permission by Percepio AB.
