Start coding now with CodeWarrior development suites!
Document created by Monica Arvizu Employee on Sep 9, 2012Last modified by Diana Torres on Feb 28, 2017
Version 2Show Document
  • View in full screen mode
If you recently acquired the CodeWarrior Development Suite, you'll find this document very useful; it provides access and technical support to a multitude of CodeWarrior products.
This quick start also explains how to register your CodeWarrior Development Suite (Section A). Section Bexplains how to activate and install one of your products. Section C describes other items that come with your CodeWarrior Development Suite, and Section D discusses the available purchase options. Section E contains the Technical Support Certificate.
As you may not have access to fully license all the CodeWarrior products, keep the following Web link handy, as it lists all the products in the differently priced levels of the CodeWarrior Development Suites (Basic, Standard and Professional).
www.freescale.com/CodeWarriorSuites
Check it out now! CodeWarrior Development Suite Quick Start
    Outcomes
