Description | Implements a wrapper for the FAT FS File System implemented by ChaN (see: http://elm-chan.org/fsw/ff/00index_e.html) |
Component | FAT_FileSystem.PEupd |
Dependencies | FreeRTOS, SD_Card |
License : Open Source (LGPL)
Copyright : (c) Copyright Erich Styger, 2012, all rights reserved.
FatFS: Copyright (C) 2011, ChaN, all right reserved. (see copyright notice and license in the FatFS implementation).
This an open source software implementing an interface to the ChaN FatFS using Processor Expert.
This is a free software and is opened for education, research and commercial developments under license policy of following terms:
* This is a free software and there is NO WARRANTY.
* No restriction on use. You can use, modify and redistribute it for personal, non-profit or commercial product UNDER YOUR RESPONSIBILITY.
* Redistributions of source code must retain the above copyright notice.
