Setting i.MX8M Mini and Nano MIPI-DPHY Clock
Document created by rogeriopimentel Employee on Dec 20, 2019Last modified by rogeriopimentel Employee on Dec 27, 2019
Version 9Show Document
  • View in full screen mode
The D-PHY PLL (in the red circle in the picture below) is the PLL that drives the MIPI Clock lane. It must be set in accordance with the video to be sent to the display.
Calculating the video bandwidth
The video bandwidth is calculated with the following equation:
Pixels per second = Horizontal res. x Vertical res. x Frame rate x Bits per pixel
Taking as example the 1080p60 OLED display RM67191:
Pixels per second = 1920 x 1080 x 60 x 24
Pixels per second = 2985984000 = 2,98Gpixels/sec
Pixel clock calculation
The Display pixel clock can be obtained on the display driver. In this example for RM67191, the pixel clock is 132Mpixel/sec, see file:
panel-raydium-rm67191.c\panel\drm\gpu\drivers - linux-imx - i.MX Linux kernel
Line 530:
.pixelclock = { 66000000, 132000000, 132000000 },
Or the number can be obtained with the following equation:
pixel clock = (hactive + hfront_porch + hsync_len + hback_porch) x (vactive + vfront_porch + vsync_len + vback_porch) x frame rate
pixel clock = (1080 + 20 + 2 +34) × (1920 + 10 + 2 + 4) x 60
pixel clock = 132000000 (rounded up)
Bit clock calculation (clock lane)
The mipi-dphy bit_clk is the output clock and is calculated on file sec-dsim.c (line 1283):
sec-dsim.c\bridge\drm\gpu\drivers - linux-imx - i.MX Linux kernel
Bit clock can be calculated with the following equation:
bit_clk = Pixel clock * Bits per pixel / Number of lanes
In the case of 1980p60 (Raydium display), It is:
bit_clk = pixel clock * bits per pixel / number of lanes
bit_clk = 132000000 * 24 / 4
bit_clk = 792000000
Other important timing parameters like 'p', 'm', 's' are obtained on the table in the following header file:
sec_mipi_dphy_ln14lpp.h\imx\drm\gpu\drivers - linux-imx - i.MX Linux kernel
    Outcomes
