E-Reader
Document created by Fabian Ramirez Employee on Nov 19, 2019Last modified by Fabian Ramirez Employee on Nov 26, 2019
Version 3Show Document
  • View in full screen mode
Description
An e-reader allows a user to download text files from the internet or from a PC, store and read multiple books, as well as to listen to audiobooks or music stored on the device.
Block Diagram
Products
Category Name 1:
MPU
Product URL 1
i.MX 8M Mini Applications Processor | Arm Cortex A53/M4 | 1080P display | NXP
Product Description 1
The i.MX 8M Mini is NXP’s first embedded multicore application processor built using advanced 14LPC FinFET process technology, providing more speed and improved power efficiency.
Category Name 2:
Battery Charger
Product URL 1
MC34673 | Single-cell Battery Charger | NXP
The MC34673 is a cost-effective fully-integrated battery charger for Li-Ion or Li-Polymer batteries. It tolerates an input voltage up to 28 V,
Category Name 3:
PMIC
Product URL 1
14-channel power management IC optimized for i.MX 8M | NXP
The PF4210 is a high-performance PMIC that is optimized to power low-cost consumer applications with the i.MX 8M family of application processors. It can provide power for a complete system, including application processors, memory and system peripherals.
Category Name 4:
Power switch
Product URL 1
USB PD and type C current-limited power switch | NXP
The NX5P3090 is a precision adjustable current-limited power switch for USB PD application, it includes under-voltage lockout, over-temperature protection, and reverse current protection circuits.
Category Name 5:
USB Type-C Logic
Product URL 1
PTN5150 | NXP
PTN5150 is a small thin low power CC Logic chip supporting the USB Type-C connector, it enables USB Type-C connector to be used in both host and device ends of the Type-C cable.
Related Documentation
Document URL
Title
https://www.nxp.com/docs/en/application-note/AN12410.pdf
i.MX 8M Mini Power Consumption Measurement
https://www.nxp.com/docs/en/application-note/AN1902.pdf
AN1902 (Combined with AN10365), Assembly guidelines for QFN (quad flat no-lead) and SON (small outline no-lead) packages
Tools
Training
Related Demos from Communities
    Outcomes
