E-cigs
Document created by Fabian Ramirez Employee on Nov 19, 2019Last modified by Fabian Ramirez Employee on Nov 26, 2019
Version 2Show Document
  • View in full screen mode
Description
E-cigs is a battery-powered device consist of an electronic cigarette that converts liquid nicotine into a mist, or vapor. It offers an interactive display that allows checking for the battery of the e-cig, liquid nicotine levels, temperature of the device, etc.
Block Diagram
Products
Category Name 1:
Microcontroller
Product URL 1
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mcus/kl-series-cortex-m0-plus/kinetis-kl2x-72-96-mhz-usb-ultra-low-power-microcontrollers-mcus-based-on-arm-cortex-m0-plus-core:KL2x
Product Description 1
The KL2x is an ultra-low-power MCU family that adds a full-speed USB 2.0 On-the-Go (OTG) controller and a 16-bit ADC with configurable resolution. The KL2x also features a FlexIO module that supports a wide range of protocols including UART, I²C, SPI, I²S, PWM waveform generation.
Product link 2
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mcus/lpc54000-cortex-m4-/low-power-microcontrollers-mcus-based-on-arm-cortex-m4-cores-with-optional-cortex-m0-plus-co-processor:LPC541XX
Product Description 2
The LPC541xx is a single-core or dual-core MCU, In an always-on application the MCUs operates in a power-down mode, listening for incoming data, which when available, can wake either core to acquire or process the information. The LPC541xx has a 12-bit ADC with 12 input channels and with multiple internal and external trigger inputs and sample rates of up to 5.0 MSamples/sec.
Category Name 2:
Real-time clock/calendar
Product URL 1
https://www.nxp.com/products/peripherals-and-logic/signal-chain/real-time-clocks/rtcs-with-ic-bus/real-time-clock-calendar:PCF8563
The PCF8563 is a CMOS Real-Time Clock (RTC) and calendar optimized for low power consumption. All addresses and data are transferred serially via a two-line bidirectional I²C-bus with a maximum bus speed of 400 kbit/s.
Category Name 3:
Secure Authenticator IC
Product URL 1
https://www.nxp.com/products/security-and-authentication/authentication/secure-authenticator-ic-embedded-security-platform:A1006
The A1006 Secure Authenticator IC is manufactured in a high-density submicron technology. It is a secure tamper-resistant authentication IC, which offers a strong cryptographic solution intended to be used by device manufacturers to prove the authenticity of their genuine products.
Related Documentation
Document URL
Title
https://www.nxp.com/docs/en/application-note/AN5133.pdf
Emulating I2C Bus Master by using FlexIO
https://www.nxp.com/docs/en/application-note/AN4568.pdf
Understanding the 16-bit ADC PGA
in Kinetis K series
https://www.nxp.com/docs/en/application-note/AN11538.zip
LPC 5411x SCTimer/PWM cookbook
https://www.nxp.com/docs/en/application-note/TN00031.zip
LPC5411x Crystal-less USB Solution
Related Software
Training
    Outcomes
