Release Announcement: Model-Based Design Toolbox for SPT version 1.3.0
Product Release Announcement
Automotive Microcontrollers and Processors
SPT - 1.3.0
Austin, Texas, USA
November 11th, 2019
Model-Based Design Toolbox for SPT allows fast prototyping of algorithms that handle sampled RADAR signals directly from MATLAB environment via SPT bit-exact Simulator.
DownloadLocation:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MBDSPT
Activation link
Release Content (updates relative to previous version)
  • Support for the flowing instructions:
  • ADD
  • FIR
  • HIST
  • IRDX2
  • IRDX4
  • MAXS
  • PDMA
  • RDX2
  • RDX4
  • SCP
  • SORT (SPT 3.0 only)
  • SUB
  • VMT
  • WIN
  • Add support for Adaptive Scaling for RDX2/RDX4/IRDX2/IRDX4 instructions
  • Add LSFR feature for the PDMA instruction
  • Update SPT 2.0, 2.5 and 2.8 bit exact simulator to version 3.0.0
  • Update SPT 3.0 bit exact simulator to version 2.0.19. To enable SPT 3.0 simulator a special license is needed. Please contact the NXP support to get access to such license
  • Integrate Help and Examples into MATLAB documentation framework. Opening the MATLAB Help will show new section of “Supplemental Software” for Model-Based Design for SPT Toolbox.
  • To enable SPT 3.0 simulator a special license is needed. Please contact the NXP support to get access to such license.
  • Redesign all SPT Toolbox examples and added a new standalone RADAR application to showcase object detection capabilities with RADAR SPT instruction: range FFT, doppler FFT, beamforming and peak search
Comments
Our customers used SPT2.0 with NXP_RADAR_TOOLBOX1.2.0 to run SPT_Example.m normally, but after upgrading to NXP_RADAR_TOOLBOX1.3.0, some errors occurred. Please help to check the reason.
The picture is as follows:
SPT2.0+NXP_RADAR_TOOLBOX1.2.0  is OK
SPT2.0+NXP_RADAR_TOOLBOX1.3.0 have some issues.
Hi,Hao Ren:
I have the same problem with you,having taken a lot time but  failed to solve the problem,could you please tell me how to solve the problem? appreciate very much!
Hello nxf47389‌,
You should uninstall the toolbox SPT_2.0_64-bit. This is one of the earliest version of NXP_RADAR_Toolbox_for_S32R.
The error is because there was added a new argument to the following mex files: rdx2_mex, rdx4_mex, irdx2_mex, and irdx4_mex.
syntax for SPT 2.x
[M_Out, adptv_acc_shift] = rdx2_mex(M_Tw, M_Op, fft_rnd, real_fft, quad_ext, repeat, shft_val, adptv)
[M_Out, adptv_acc_shift] = rdx4_mex(M_Wc_Tw, M_Op, win_type, win_coeff_type, fft_rnd, quad_ext, repeat, shft_val, adptv)
[M_Out, adptv_acc_shift] = irdx2_mex(M_Tw, M_Op, fft_rnd, quad_ext, repeat, shft_val, adptv)
[M_Out, adptv_acc_shift] = irdx4_mex(M_Wc_Tw, M_Op, win_type, win_coeff_type, fft_rnd, quad_ext, repeat, shft_val, adptv)
syntax for SPT 3.0
[M_Out, adptv_acc_shift] = rdx2_mex(M_Tw, M_Op, fft_rnd, real_fft, quad_ext, shft_val, adptv)
[M_Out, adptv_acc_shift] = rdx4_mex(M_Wc_Tw, M_Op, win_type, win_coeff_type, fft_rnd, quad_ext, shft_val, adptv)
[M_Out, adptv_acc_shift] = irdx2_mex(M_Tw, M_Op, fft_rnd, quad_ext, shft_val, adptv)
[M_Out, adptv_acc_shift] = irdx4_mex(M_Wc_Tw, M_Op, win_type, win_coeff_type, fft_rnd, quad_ext, shft_val, adptv)
adptv_acc_shift is the adaptive scaling accumulated shift
adptv is the adaptive scaling type; valid values are:
  • 'NO_ADPTV' - disable adaptive scaling
  • 'ADPTV_TYPE1' - MSB occupation counter counts unoccupied bits from bit 15 downwards
  • 'ADPTV_TYPE2' - MSB occupation counter counts unoccupied bits from bit:
    • 23 downwards for SPT 2.0, 2.8 and 3.0
    • 19 downwards for SPT 2.5
Iulian Bulancea
No ratings
Version history
Last update:
‎11-12-2019 12:33 AM
Updated by:
