The i.MX8MM suspend power test on the modified boards with 4.14.98 post GA release
Document created by Jack Mao Employee on Jun 4, 2019Last modified by Jack Mao Employee on Jun 17, 2019
Version 3Show Document
  • View in full screen mode
After rework the board, enable two OTG controllers in Linux DTB file and disable VBUS valid comparator when in suspend mode by clear USB_OTGx_PHY_CTL2 bit 16.  Then we get the following power data on suspend mode
  • Suspend Mode
    ****  The page is under internal check ****
Outcomes
