Useful LPC documents and questions
Document created by Erik Bustos Employee on May 23, 2019Last modified by Erik Bustos Employee on May 30, 2019
Version 3Show Document
  • View in full screen mode
The following document contains a list of documents, questions and discussions that are relevant in the community based on the amount of views they are receiving each month. If you are having a problem, doubt or getting started in LPC or MCUXpresso you should check the following links to see if your doubt have been already solved in the following documents and discussions.
MCUXpresso
MCUXpresso Supported Devices Table
FAQ: MCUXpresso Software and Tools
How to create a new LPC project using LPCOpen and MCUXpresso IDE
Introducing MCUXpresso SDK v.2 for LPC54xxx Series
Generating a downloadable MCUXpresso SDK v.2 package
Using the MCUXpresso Pins Tool
MCUXpresso Config Tools is now available!
LPC55xx Multicore Applications with MCUXpresso IDE
LPC information
LPC5460x MCU Family Overview
USB with NXP Microcontrollers
LWIP memory requirements
LPC800 Four-Part Webinar Series!
The LPC804 Programmable Logic Unit (PLU)
LPC84x Technical Training - Now Available
Guides and Examples
Flashing and Installing the new firmware and drivers for LPC11U35 debug probes
Enabling debug output
USB FLASH download, programming, and security tool (DFUSec)
DMA Ping-Pong application
Getting start with LPCXpresso54608 & emWin Graphics;
Capacitive Touch example using the LPC845 Breakout Board
OLED Display Application Example using LPC845 Breakout Board and SPI
Mixed-Signal Logic Analyzer & Oscilloscope (Lab Tool) Solution
LPC FAQ
How to calculate the value of crystal load capacitors?
Can I send a message with X/Y/Z bits in the ID?
What is the difference between error active and error passive?
What is the sample point for?
How can I verify the configured CAN bitrate, using an oscilloscope?
    Outcomes
