S32DS - list of HOWTOs
Document created by Mike Doidge Employee on Dec 14, 2018Last modified by Mike Doidge Employee on Dec 31, 2019
Version 15Show Document
  • View in full screen mode
Installation & Activation
HOWTO: Install Lauterbach TRACE32 debugger plug-in into S32 Design Studio
HOWTO: Activate S32 Design Studio
HOWTO: S32 Design Studio - Offline Install of Extensions and Updates
S32DS Extensions & Updates: Explanation and How To Use
Getting Started
HOWTO: S32 Design Studio - Create a New S32DS Project from Example
HOWTO: S32 Design Studio - Create a New Application Project
HOWTO: Create a simple blinking LED project using S32 Config Tool (S32V2xx) NEW!
Build tools & Standard libraries
HOWTO: Build a Project and Setup a Debug Configuration for debugging in S32 Design Studio
HOWTO: Add a static library file into S32 Design Studio GCC project
HOWTO: Link a binary file(s) into the application project using GNU build tools
Debug  & Flash Programming
HOWTO: Setup S32V234 EVB for debugging with S32DS for Vision and Linux BSP
Using GDB Server Monitor Commands from Eclipse GDB Console
HOWTO: Setup static IP address for S32 debug probe
Debugging the Startup Code with Eclipse and GDB | MCU on Eclipse
HOWTO: Start Trace with S32 Debugger and S32 Debug Probe NEW!
HOWTO: Add a new debugger configuration to an existing project NEW!
S32 SDK & Other SDKs
HOWTO: Working with AMMCLib SDKs
HOWTO: Add custom SDK into existing project
Implementing FreeRTOS Performance Counters on ARM Cortex-M | MCU on Eclipse
General Usage
HOWTO: S32 Design Studio Command Line Interface
HOWTO: Generate S-Record/Intel HEX/Binary file
HOWTO: Migrate Application Projects from S32DS for Vision 2018.R1 to S32DS 3.x
Troubleshooting
Troubleshooting: PEmicro Debug Connection: Target Communication Speed
Troubleshooting: Indexer errors on header file
Troubleshooting: PEMicro Debugging: PIT and STM modules cannot count when Debug Mode is entered
Troubleshooting: PEMicro Debugging: Problems resuming from breakpoint in vTaskDelay
Troubleshooting: Quick Fix Option in Problems View
Troubleshooting: Installer rolls back immediately following activation code entry
Troubleshooting: Activation fails with error message FNP ERROR 0
    Outcomes
