FreeRTOS advanced programming for NXP Rapid-IoT
Document created by Theophile Leroy Employee on Nov 2, 2018Last modified by Theophile Leroy Employee on Nov 2, 2018
Version 2Show Document
  • View in full screen mode
Dear NXP Rapid-IoT users,
Here is another example demonstrating FreeRTOS capabilities for NXP Rapid-IoT and how to display menus using the ui manager module.
(please find the attached code below)
Note: This is an advanced example and requires C code programming skills as well as some background in real-time system programming.
For more information about FreeRTOS see the API reference guide.
This example demonstrates how to use basic multi-task features in order to handle a multi-screen environment application.
In this example you will find three screens:
Welcome Screen
(T3 / Top Touch)
Temperature screen
(T2 / Right Touch)
Humidity screen
(T4 / Left Touch)
Four tasks are created :
  • UiManager task: Handle touch buttons event and screen transitions
  • Main screen task: Display the main screen
  • Temperature screen task: Display the temperature measurements from ENS210 sensor
  • Humidity screen task: Display the humidity measurements from ENS210 sensor
  • + mutex-semaphore is implemented to handle shared resources between tasks (Display & sensors)
Screens are described in an object-oriented manner to easily manage them in the task's code:
.navigation describe how the menu transition will behave
.title & .image will be used to display correct information
.start/stopTaskFunction will be used to create/pause the according measurement&display task.
example_1b.h
static guiScreen_t
    gui_example1b_mainScreen =
        .navigation =
            .up     = NULL,
            .down   = NULL,
            .left   = &gui_example1b_humScreen,
            .right  = &gui_example1b_tempScreen
        .title = "Welcome !",
        .image = nxp_logo,
        .startTaskFunction  = &gui_example1b_mainScreen_StartTask,
        .stopTaskFunction = &gui_example1b_mainScreen_StopTask
Source code is located under "/source" folder
- example_1b.c/h
- main.c (main_task entry point l.272)
Ui manager code is located under "/ui_manager" folder
- ui_manager.c/h
To import project into MCUXpresso :
   - Import project(s) from file system...
   - Choose archive, then select the downloaded archive
Please, feel free to take a deep look into the code, tinker and develop your own application.
Don't hesitate to share with us any questions/remarks you may have.
Outcomes
