HSM-backed Code-Signing Tool
Document created by Marouene Boubakri Employee on Sep 28, 2018Last modified by Marouene Boubakri Employee on Jan 10, 2019
Version 6Show Document
  • View in full screen mode
This document provides the information necessary for the user to effectively use Code-Signing Tool with Hardware Security Module backend. It is primarily intended for users who are familiar with CST tool to sign codes for the NXP High Assurance Boot (HAB) and NXP Advanced High Assurance Boot (AHAB).
1. Getting started
Refereeing to "Appendix B, Replacing the CST Backend Implementation” of Code-Signing Tool User’s Guide, NXP has architected the Code-Signing Tool in two parts a Front-End and a Back-End. The Front-End contains all the NXP proprietary operations, while the Back-End containing all standard cryptographic operations. Users can write a replacement for the reference backend to interface with a HSM.
The reference backend uses OpenSSL to perform HAB signature generation and encrypted data generation. OpenSSL in his turn, exposes an Engine API, which makes it possible to plug in alternative implementations for some of the cryptographic operations implemented by OpenSSL. We can take advantage of this to reuse the reference backend with a HSM by offloading cryptographic operations involved during signature generation to HSM.
The engine should re-write an implementation of RSA private encrypt function, ECDSA sign function and how public certificates and private keys are loaded from the HSM to the appropriate data structure X509, RSA, EVP_PKEY and EC_KEY. Optionally SHA digest functions can be re-written also to be performed at the HSM level.
1.1    PKCS#11 enabled HSM
PKCS#11 is a standardized interface for cryptographic tokens which exposes an API called Cryptoki. Cryptographic token manufacturers provide shared libraries (.so or .dll) which implements PKCS#11 standard. Those libraries can be used as bridge between the HSM and the CST Back-End. Typically, the engine loads the shared PKCS#11 module and invoke the appropriate functions on it.
The following figure illustrates the architecture of Code-Signing Tool with a Backend replacement to interface with a PKCS#11 enabled HSM.
 CST with HSM Backend architecture
Figure 1HSM-backed CST architecture
The green part of the architecture represents a custom built-in OpenSSL engine which uses PKCS#11 interface to interact with HSM via PKCS#11 implementation library provided by the HSM vendor. It implements all required functions to manage session and tokens, load public certificates, private keys, sign and hash.
Slight modification should be done at the reference backend (blue part) to initialize the engine, perform control command and configuration. In the reference backend public certificates and private keys are loaded from file system. This should be replaced respectively by ENGINE_load_certificate and  ENGINE_load_private_key to load cryptographic material from HSM into appropriate data structures which can be used later. Those functions are bound to low-level functions implemented in the engine.
Below is a non-exhaustive list of well-known smartcards/tokens which support PKCS#11 and the suggested library filename to use.
- aetpkss1.dll (for G&D StarCos and Rainbow iKey 3000)
- cs2_pkcs11.dll (for Utimaco CryptoServer LAN)
- CccSigIT.dll (for IBM MFC)
- pk2priv.dll (for GemSAFE, old version)
- gclib.dll (for GemSAFE, new version)
- dspkcs.dll (for Dallas iButton)
- slbck.dll (for Schlumberger Cryptoflex and Cyberflex Access)
- SetTokI.dll (for SeTec)
- acpkcs.dll (for ActivCard)
- psepkcs11.dll (for A-Sign Premium)
- id2cbox.dll (for ID2 PKCS#11)
- smartp11.dll (for SmartTrust PKCS#11)
- pkcs201n.dll (for Utimaco Cryptoki for SafeGuard)
- dkck201.dll (for DataKey and Rainbow iKey 2000 series)
- cryptoki.dll (for Eracom CSA)
- AuCryptoki2-0.dll (for Oberthur AuthentIC)
- eTpkcs11.dll (for Aladdin eToken, and some Siemens Card OS cards)
- cknfast.dll (for nCipher nFast or nShield)
- cryst201.dll (for Chrysalis LUNA)
- cryptoki.dll (for IBM 4758)
- softokn3.dll (for the Mozilla or Netscape crypto module)
- iveacryptoki.dll (for Rainbow CryptoSwift HSM)
- sadaptor.dll (for Eutron CryptoIdentity or Algorithmic Research MiniKey)
- pkcs11.dll (for TeleSec)
- siecap11.dll (for Siemens HiPath SIcurity Card API)
- asepkcs.dll (for Athena Smartcard System ASE Card)
- /opt/SUNWconn/cryptov2/lib/libvpkcs11.so (for SUN Crypto Accelerator 4000, 32-bit libraries)
- /opt/SUNWconn/cryptov2/lib/sparcv9/libvpkcs11.so (for SUN Crypto Accelerator 4000, 64-bit libraries)
- /opt/SUNWconn/crypto/lib/libpkcs11.so (for SUN Crypto Accelerator 1000, 32-bit libraries)
- /opt/SUNWconn/crypto/lib/sparcv9/libpkcs11.so (for SUN Crypto Accelerator 1000, 64-bit libraries)
1.2    Client/Server based HSM
The HSM-backend is mainly written for PKCS#11 enabled HSMs. In case of Client/Server based HSM the built-in engine can be adapted to implement a client to consume a server exposed API for example. The following requirement should be fulfilled:
-   Locate keys/certificates on HSM by an identifier, name or label. This identifier will be kept across cryptographic operation.
-   Load partial attributes of private key. In case of RSA should be able to get the value of the modulus and the exponent. It is mandatory to populate RSA structure with those parameters for private keys. OpenSSL uses that for consistency check between certificate and its corresponding private key. In case your HSM is not able to provide partial private keys parameters, you should patch OpenSSL to ignore X509_check_private_key function.
-   Write an implementation for RSA init / finish methods and rsa_priv_encrypt method.
-   Optionally implement SHA diget methods if you want to perform digesting at HSM level. Methods are: digest_init, digest_update, digest_finish, digest_copy and digest_cleanup
-   Engine initialization and destruction.
-   In case of stateful service, add a session manager to your implementation.
2. Installation
2.1    Dependencies
The CST-HSM backend depends on:
  • OpenSSL library
  • Libconfig
Make is required for building the software.
Linux
1) Install OpenSSL
$ apt-get install openssl libssl-dev
libconfig  is a C/C++ library for processing structured configuration files. It is used by CST to load HSM related configuration.
2) Install libconfig
$ apt-get install libconfig-dev
Windows
Under Windows all setup can be done in top of MSYS2 and MinGW.
1) Install MinGW toolchain
For 32-bit:
$ pacman -S mingw-w64-i686-gcc make
For 64-bit:
$ pacman -S mingw-w64-x86_64-gcc make
2) Install OpenSSL libraries
You can search the repositories by doing:
$ pacman -Ss openssl-devel
Then install using
3) Install Libconfig libraries
Search for libconfig-devel and install it by doing:
$  pacman -Ss libconfig
For 32-bit:
$ pacman -S mingw-w64-i686-libconfig
For 64-bit:
$ pacman -S mingw-w64-x86_64-libconfig
2.2    Get sources
The HSM backend source code for CST can be found in the official CST package or checked-out internally from Bitbucket repository.
2.3    Compile sources
2.3.1 Compile Backend
1) Verify that the compiler is working by doing:
 $ gcc -v
For Windows open a MSYS2 MinGW 64-bit or a MSYS2 MinGW 32-bit shell.
2) Compile the backend source code using the following command:
From CST package:
$ tar xzf cst-release.tgz
$ cd release/code/back_end-hsm/src/
$ make
If you have a custom OpenSSL version or installation and you want to compile the backend against it you can use OPENSSL_PATH attribute and specifies the path to it.
$ make OPENSSL_PATH=/opt/openssl-1.1.0
The result is libbackend.a static library present in the current working folder.
2.3.1 Compile Code-Signing tool
Taking into consideration the target architecture, copy libfrontend.a to current working directory (where libbackend.a resides) and then compile CST using the following command:
$ cp ../../../linux64/lib/libfrontend.a .
$ make all
The result is ./cst binary file created in the current working directory .
Optionally, copy or create a symlink to the created cst binary file on linux64/bin folder.
$ ln -s ./cst ../../../linux64/bin/cst-hsm
3. Deploy
This section provides instructions and prerequisites to deploy Code-Signing Tool with 2 HSMs, these are SoftHSM2 and Utimaco HSM simulator.
3.1    Install HSM
3.1.1   SoftHSM2
Install SoftHSM2
$ apt-get install softhsm2
Use either softhsm2-util to initialize a token. The SO PIN can e.g. be used to re-initialize the token and the user PIN is handed out to the application so it can interact with the token.
$ softhsm2-util --init-token --slot 0 --label "CST-HSM"
Type in SO PIN and user PIN.
=== SO PIN (4-255 characters) ===
Please enter SO PIN: ******
Please reenter SO PIN: ******
=== User PIN (4-255 characters) ===
Please enter user PIN: ******
Please reenter user PIN: ******
The token has been initialized and is reassigned to slot 66362367
Initialized tokens will be reassigned to another slot (based on the token serial number). It is recommended to find and interact with the token by searching for the token label or serial number in the slot list / token info.
3.1.2   Utimaco HSM Simulator
Download and extract SecurityServerEvaluation package.
$ cd SecurityServerEvaluation-V4.20.0.4/Software/Linux/Simulator/sim5_linux/bin
$ ./cs_sim.sh
Copy cs_pkcs11_R2.cfg to /etc
$ cp /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/sample/cs_pkcs11_R2.cfg /etc
Edit /etc/cs_pkcs11_R2.cfg configuration file and
Uncomment Logpath = /tmp in [Global] section
Add Device = 3001@127.0.0.1 to [CryptoServer] section
Save the file
Install java if it is not installed on your system
$ apt-get install default-jre
Launch p11cat
$ java -jar /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Administration/p11cat.jar
From the menu bar click Login/Logout
Select a slot from the Slot List grid
Select Login Generic
Type ADMIN as UserName
Select Keyfile as Authenticiation Token
Click browse button and fin the ADMIN.key file
The keyfile is under SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Administration/key/ADMIN.key
Click Login
HSM configuration 1
From Slot Management menu click
In Init Token form define the Token Label and SO PIN then click Init Token
HSM configuration 2
From Login/Logout menu click Logout All
From Login/Logout menu click Login SO
HSM configuration 3
From Slot Management menu click Init PIN
Set User PIN for example 123456
HSM configuration 4
3.3 Public Certificates & keys
If you already have the cryptographic material on the disk, please go directly to Push cryptographic material to HSM section.
If you have the cryptographic material on the HSM, please go directly to pull Cryptographic material from HSM.
Referring to Key and Certificate Generation HAB Code Signing Tool User’s guide, generate keys and certificates which will be used to sign boot loader image.
3.3.1   Create serial file
OpenSSL uses the contents of serial file for the certificate serial numbers.
$ cd release/keys
$ echo "28280581" > serial
3.3.2   Create passphrase file
key_pass.txt - Contains your pass phrase that will protect the HAB code signing private keys.
$ echo "maro1337" > key_pass.txt
$ echo "maro1337" >> key_pass.txt
3.3.3   Generate the PKI tree
HAB
$ ./hab4_pki_tree.sh
When prompts please answer according to the following:
Do you want to use an existing CA key (y/n)?: nDo you want to use Elliptic Curve Cryptography (y/n)?: nEnter key length in bits for PKI tree: 2048Enter PKI tree duration (years): 10How many Super Root Keys should be generated? 4Do you want the SRK certificates to have the CA flag set? (y/n)?: y
Private keys will generate on keys directory and corresponding Certificates are placed in the crts directory.
AHAB
$ ./ahab_pki_tree.sh
Do you want to use Elliptic Curve Cryptography (y/n)?: y
Enter length for elliptic curve to be used for PKI tree:
Possible values p256, p384, p521:  p384
Enter the digest algorithm to use: sha384
3.3.4   Generate SRK table
Create fuse table and binary (SRK table) to be flashed.
HAB
$ cd ../crts
$ ../linux64/bin/srktool -h 4 -t SRK_1_2_3_4_table.bin -e SRK_1_2_3_4_fuse.bin -d sha256 -c ./SRK1_sha256_2048_65537_v3_ca_crt.pem,./SRK2_sha256_2048_65537_v3_ca_crt.pem,./SRK3_sha256_2048_65537_v3_ca_crt.pem,./SRK4_sha256_2048_65537_v3_ca_crt.pem -f 1
SRK_1_2_3_4_table.bin - SRK table contents with HAB data
SRK_1_2_3_4_fuse.bin - contains SHA256 result to be burned to fuse
AHAB
$ cd ../crts
$ ../linux64/bin/srktool -a -s sha384 -t SRK1234table.bin -e SRK1234fuse.bin -f 1 -c SRK1_sha384_secp384r1_v3_ca_crt.pem,SRK2_sha384_secp384r1_v3_ca_crt.pem,SRK3_sha384_secp384r1_v3_ca_crt.pem,SRK4_sha384_secp384r1_v3_ca_crt.pem
SRK1234table.bin - SRK table contents with AHAB data
SRK1234fuse.bin - contains SHA384 result to be burned to fuse.
3.3.4   Command Sequence File (CSF)
CST tool requires CSF script. This file describes certificates, keys and the data ranges used in sign and encryption functions.
HAB
Create u-boot.csf file.
$ cd ../linux64/bin/
$ nano u-boot.csf
[Header]
Version = 4.1
Security Configuration = Open
Hash Algorithm = sha256
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
Engine = CAAM
[Install SRK]
File = "../../crts/SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
File = "../../crts/CSF1_1_sha256_4096_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
# Key slot index used to authenticate the key to be installed
Verification index = 0
# Key to install
Target index = 2
File = "../../crts/IMG1_1_sha256_4096_65537_v3_usr_crt.pem"
[Authenticate Data]
Verification index = 2
Blocks = 0x00000000 0 0xd4454 "flash.bin"
AHAB
The CSF contains the input files and keys used by CST to create the final image already signed. Please report the offsets noted previously when run mkimage.
[Header]
Target = AHAB
Version = 1.0
[Install SRK]
# SRK table generated by srktool
File = "../../crts/SRK1234table.bin"
# Public key certificate in PEM format
Source = "../../crts/SRK1_sha384_secp384r1_v3_ca_crt.pem"
# Index of the public key certificate within the SRK table (0 .. 3)
Source index = 0
# Type of SRK set (NXP or OEM)
Source set = OEM
# bitmask of the revoked SRKs
Revocations = 0x0
[Authenticate Data]
# Binary to be signed generated by mkimage
File = "flash.bin"
# Offsets = Container header  Signature block (printed out by mkimage)
Offsets   = 0x400             0x590
3.4    Push cryptographic material to HSM
3.4.1   Install p11tool
To perform interact with HSM you can use p11tool.
$ apt-get install gnutls-bin
3.4.2   Find Token URL
You need to locate your HSM vendor’s PKCS#11 interface implementation in order to use it with p11tool and CST later.
Utimaco pkcs#11 library is SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86 64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so
SoftHSM2 pkcs11# library is /usr/lib/softhsm/libsofthsm2.so
Find the Token URL to interact with the token.
$ p11tool --provider <pkcs11_lib_path> --list-tokens
Example using SoftHSM2
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so --list-tokens
Token 0:
        URL: pkcs11:model=SoftHSM%20v2;manufacturer=SoftHSM%20project;serial=9c1aeb00e05a348b;token=CST-HSM
        Label: CST-HSM
        Type: Generic token
        Manufacturer: SoftHSM project
        Model: SoftHSM v2
        Serial: 9c1aeb00e05a348b
        Module: (null)
 In this case Token URL is:
3.4.3   Push certificate & key
To match a certificate to a private key, both should have the same ID, for some other HSM implementations they should have the same label.
HAB
Push CSF certificate and private key
Private Key:
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so "pkcs11:model=CryptoServer;manufacturer=Utimaco%20IS%20GmbH;serial=UTIMACO%20CS000000;token=CryptoServer%20PKCS11%20Token" so  --login --write --load-privkey ../../keys/CSF1_1_sha256_2048_65537_v3_usr_key.pem --label CSF1_1_sha256_2048_65537_v3_usr --id ec705018e9bf8ad60096e13cb2f0fbad
Certificate:
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so "pkcs11:model=CryptoServer;manufacturer=Utimaco%20IS%20GmbH;serial=UTIMACO%20CS000000;token=CryptoServer%20PKCS11%20Token" so  --login --write --load-certificate ../../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem --label CSF1_1_sha256_2048_65537_v3_usr --id ec705018e9bf8ad60096e13cb2f0fbad
 SoftHSM2
Private Key:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so  --login --write “<token-url>” --load-privkey ../../keys/CSF1_1_sha256_2048_65537_v3_usr_key.pem --label CSF1_1_sha256_2048_65537_v3_usr --id ec705018e9bf8ad60096e13cb2f0fbad
Certificate:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so  --login --write "<token-url>" --load-certificate ../../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem --label CSF1_1_sha256_2048_65537_v3_usr --id ec705018e9bf8ad60096e13cb2f0fbad
Push IMG certificate & key
Private key:
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so "pkcs11:model=CryptoServer;manufacturer=Utimaco%20IS%20GmbH;serial=UTIMACO%20CS000000;token=CryptoServer%20PKCS11%20Token" so  --login --write --load-privkey ../../keys/IMG1_1_sha256_2048_65537_v3_usr_key.pem --label IMG1_1_sha256_2048_65537_v3_usr --id a0c8cac03985fb6dced29c97dc83aef7
Certificate:
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so "pkcs11:model=CryptoServer;manufacturer=Utimaco%20IS%20GmbH;serial=UTIMACO%20CS000000;token=CryptoServer%20PKCS11%20Token" so  --login --write --load-certificate ../../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem --label IMG1_1_sha256_2048_65537_v3_usr --id a0c8cac03985fb6dced29c97dc83aef7
SoftHSM2
Private key:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so  --login --write "<token-url>"  --load-privkey ../../keys/IMG1_1_sha256_2048_65537_v3_usr_key.pem --label IMG1_1_sha256_2048_65537_v3_usr --id a0c8cac03985fb6dced29c97dc83aef7
Certificate:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so  --login --write "<token-url>"  --load-certificate ../../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem --label IMG1_1_sha256_2048_65537_v3_usr --id a0c8cac03985fb6dced29c97dc83aef7
AHAB
For AHAB you should extract the EC public key from the private key and push it to HSM with same ID/Label as private key.
Push Private key
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so  --login --write "<token-url>"  --load-privkey ../keys/SRK1_sha384_secp384r1_v3_ca_key.pem --label SRK1_sha384_secp384r1_v3_ca_key --id b0c8cac03985fb6dced29c97dc83aef7
Push certificate
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so  --login --write "<token-url>"   --load-certificate ./SRK1_sha384_secp384r1_v3_ca_crt.pem --label SRK1_sha384_secp384r1_v3_ca_crt --id b0c8cac03985fb6dced29c97dc83aef7
Extract Public key from Private key
$ openssl ec -in relase/keys/SRK1_sha384_secp384r1_v3_ca_key.pem -pubout -out SRK1_sha384_secp384r1_v3_ca_pubkey.pem
Push Public key
$ p11tool --provider /home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so  --login --write "<token-url>"  --load-pubkey SRK1_sha384_secp384r1_v3_ca_pubkey.pem --label SRK1_sha384_secp384r1_v3_ca_pubkey --id b0c8cac03985fb6dced29c97dc83aef7
3.4.5   Verification
Verify that all cryptographic materials were correctly written to token by running.
$ p11tool --provider “<pkcs11-module>” "<token-url>"  --list-all --login
Enter PIN when prompts
3.5    Pull certificates from HSM
CST's frontend requires having certificates on the disk to perform additional process on them, hence public certificates should be pulled from HSM to local disk.
3.5.1   Install p11tool
3.5.1   Find Token URL
Token 0:
        Label: CST-HSM
        Type: Generic token
        Model: SoftHSM v2
        Module: (null)
3.4.3   Pull Certificates
HAB
Pull CSF & IMG certificate
List all certificates on HSM
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so "<token-url>"  --list-all-certs
Pull CSF certificate from HSM:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so --export "<cert-url>" --outfile CSF1_1_sha256_2048_65537_v3_ca_crt.pem
Pull IMG certificate from HSM:
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so --export "<cert-url>" --outfile IMG1_1_sha256_2048_65537_v3_ca_crt.pem
 AHAB
Pull SRK certificate
$ p11tool --provider /usr/lib/softhsm/libsofthsm2.so --export "<cert-url>" --outfile SRK1_sha384_secp384r1_v3_ca_crt.pem
3.6    Create HSM configuration file
Create a hsm.cfg file in the same folder as CST. The configuration file specifies the following parameters.
  • module contains the path to vendor’s PKCS#11 implementation library.
  • pin specifies the User PIN. For security reason this entry can be removed from configuration file. User PIN is requested during runtime when needed.
  • slot specifies the SLOT ID.
  • objects is a lookup table which bind a cryptographic material on the file system to its Object ID on the HSM. This is needed since the current frontend implementation loads and checks certificates from the file system and then provide as argument the certificate path to the backend.
    The backend can see a path only. To load the required certificate and its private key from the HSM, the backend uses this lookup.
$ nano hsm.cfg
HAB
# hsm stuff
hsm:
  module = "/home/nxf45729/SecurityServerEvaluation-V4.20.0.4/Software/Linux/x86-64/Crypto_APIs/PKCS11_R2/lib/libcs_pkcs11_R2.so";
  pin = "123456";
  slot = 0;
  objects = (
          { file  = "./CSF1_1_sha256_2048_65537_v3_usr_crt.pem";
            id = "ec705018e9bf8ad60096e13cb2f0fbad";
          { file  = "./IMG1_1_sha256_2048_65537_v3_usr_crt.pem";
            id = "a0c8cac03985fb6dced29c97dc83aef7";
AHAB
# hsm stuff
hsm:
pin = "12345678";
slot = 0;
objects = (
{ file  = "./SRK1_sha384_secp384r1_v3_ca_crt.pem";
id = "b0c8cac03985fb6dced29c97dc83aef7";
4.          RUN
Generate the CSF binary signature
$ ./cst -i u-boot.csf -o u-boot.csf.bin
CSF Processed successfully and signed data available in u-boot.csf.bin
    Outcomes
