Using a different  Flash with the RT1050
Document created by Rita Wang Employee on Jun 29, 2018
Version 1Show Document
  • View in full screen mode
In IAR/Keil environment , when you change to other flash(not default flash on EVK board), please refer to below AN to modify the code for it.
https://www.nxp.com/docs/en/nxp/application-notes/AN12183.pdf
1 person found this helpful
    Outcomes
