The board used: FRDM-KE02
SWD: The ARM Serial Wire Debug interface uses a single bidirectional data connection(SWDIO) and a separate clock (SWDCLK) to transfer data synchronously. An operation on the wire consists of two or three phases:
Packet request The external host debugger issues a request to the DP. The DP is the target of the request.
Acknowledge response The target sends an acknowledge response to the host.
Data transfer phase
First enter into SWD mode: Send at least 50 SWCLKTCK cycles with SWDIOTMS HIGH and 0xE79E. This ensures that the current interface is in its reset state and enable the SWD mode.
uint8_t SWJ_JTAG2SWD(void)
uint32_t i;
SWDIO_SET();
for(i = 0; i < 56; i++)
SW_CLOCK_CYCLE();
SWJ_SendData(0xE79E);//SWJ_SendData(0xB76D);以后遇到再加
SW_CLOCK_CYCLE();
SWDIO_CLR();
for(i = 0; i < 16; i++)
SW_CLOCK_CYCLE();
return 0;
Then write DP/AP register. A successful write operation is as below:
DP Register:
Address Read Write
0x00 IDCODE ABORT
0x04 CTRL/STAT CTRL/STAT
0x08 RESEND SELECT
0x0C RDBUFF N/A
Address Read Write
0x00 CSW CSW
0x04 TAR TAR
0x08 N/A N/A
0x0C DRW DRW
0xFC IDR N/A
Read IDCODE:
uint8_t SWJ_ReadDP(uint8_t adr, uint32_t *val)
uint32_t tmp_in;
uint8_t ack;
uint8_t err;
tmp_in = SWD_REG_DP | SWD_REG_R | SWD_REG_ADR(adr);
ack = SWD_Transfer(tmp_in, val);
(ack == DAP_TRANSFER_OK) ? (err = 0) : (err = 1);
return err;
uint8_t SWJ_ReadAP(uint32_t adr, uint32_t *val)
uint8_t tmp_in, ack, err;
uint32_t apsel = adr & APSEL;
uint32_t bank_sel = adr & APBANKSEL;
if(SWJ_WriteDP(DP_SELECT, apsel | bank_sel))
return 1;
tmp_in = SWD_REG_AP | SWD_REG_R | SWD_REG_ADR(adr);
/* first dummy read */
return err;
