Pins Tool for i.MX v4 Now Available
We are pleased to announce that Pins Tool for i.MX v4 is now available.
The pins Tool for i.MX Application Processors is used for pin routing configuration,
validation and code generation, including pin functional/electrical properties,
power rails, run-time configurations, with the following main features:
  • Desktop application
  • Muxing and pin configuration with consistency checking
  • Multicore support
  • Localized for English and Simplified Chinese
  • Mostly Connected: On-Demand device data download
  • Integrates with any compiler and IDE
  • Graphical processor package view
  • Multiple configuration blocks/functions
  • Easy-to-use device configuration
  • Documented and easy to understand source code
  • CSV Report and Device Tree File
To download the installer for all platforms, please login to our download site via:
Please refer to Pins Tool Documentation  for installation and quick start guides.
Overview of Changes - version 4
  • Added ability to import configuration from existing MEX file (for selected tools)
  • Added common Functions group toolbar across all tools
  • Added option to not generate YAML
  • Pins tool: multiselect in Routed pins view supported
  • Syntax coloring supported in Sources view
  • Export sources wizard simplified
  • Several bug fixed and performance improved
  • Quick start guide added
Community
https://community.nxp.com/community/imx
No ratings
Version history
Last update:
‎11-24-2017 08:08 AM
Updated by:
