U-BOOT GPIO Driver for LS102xa Platform
Document created by Yiping Wang Employee on Oct 8, 2017Last modified by ebiz_ws_prod on Apr 30, 2018
Version 3Show Document
  • View in full screen mode
Recently some customers are porting SDK 2.0 u-boot for LS1021ATWR to their custom boards. They intended to use GPIO lines to turn on/off LEDs for diagnostics and other various purposes. However GPIO driver is not supported in SDK 2.0 u-boot for LS102xa platform. The attached patch is used to add GPIO driver on LS1021ATWR platform based on SDK 2.0 u-boot code.
Please use it in SDK 2.0 as the following:
$ source ./fsl-setup-env -m ls1021atwr
$ bitbake u-boot -c cleansstate
$ bitbake u-boot -c patch
Go to the folder build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/git, apply the attached patch
$ patch -p1<0001-ls1021xa-gpio.patch
Go back to build_ls1021atwr folder to rebuild u-boot
$ bitbake u-boot
Original Attachment has been moved to: 0001-ls1021xa-gpio.patch.zip
    Outcomes
