WideVine on i.MX6 and GTS result
Document created by JayTu Employee on Aug 16, 2017Last modified by JayTu Employee on Aug 17, 2017
Version 2Show Document
  • View in full screen mode
BASIC INFORMATION
HW: i.MX6Q SabreSD
SW: Android N7.1.1_1.0.0
GTS version: 4.1_r2
The test result below shows all pass. (There is item failed at the first test, but pass later)
Test Report
PATCHES
  • libwvdrmengine is the NXP level3 widevine implementation. Of course, you will need apply keybox from google. The library will need use the key to communicate with google key server.
  • stagefright patch is needed before N7.1.1_1.0.0, it is merged now. The later NXP android release contains the patch.
  • For com.google.android.media.gts.WidevineHEVCPlaybackTests#testClearWith1080P30, we don't have H265 1080P HW decoder, it will fail then. To make it pass, remove the capability from media_codec.xml.
1 person found this helpful
Outcomes
