Separating Control Plane and Data Plane between GPP and AIOP on LS2085
Document created by Yiping Wang Employee on Nov 13, 2016Last modified by ebiz_ws_prod on Apr 30, 2018
Version 7Show Document
  • View in full screen mode
This document introduces a method to separate control plane and data plane between GPP(ARM) and AIOP based on different L4 protocols implemented in the AIOP software. So far, in the current MC version, this scenario could not be implemented from WRIOP using DPDMUX, so it is a good choice for users to separate the traffic in AIOP.
1. Basic Concept of DPAA2 Objects
2. AIOP Application to Implement Control in ARM and Data Plane in AIOP
3. Build AIOP Application Project with CodeWarrior
4. Running AIOP Application Program on LS2085ARDB
Original Attachment has been moved to: aiop.tar.gz
Outcomes
