LPCWare Migrated Content Important Information
Document created by Diana Torres Employee on Jun 13, 2016Last modified by Diana Torres Employee on Jun 14, 2016
Version 2Show Document
  • View in full screen mode
Dear Community User,
We recently migrated content from the LPCWare.com forums into this community site. Migrated content can be found in the following two locations: LPCXpresso IDE
for content from the LPCXpresso folder on the LPCWare.com forum, and LPC for all other content.
All imported content will appear as posted by "LPCWARE" and will have the following message displayed at the top of each thread with the original username and date posted in LPCWare:
If you wish to find the content you created in LPCWare you must:
1.-  Open the search box at the top right side of your community near your avatar.
2.- Type in the username you had set up in LPCWare and the results should automatically appear.
All responses to postings in the original LPCWare.com forums are also preserved, so if you are looking for a response you or another particular user posted then you should also be able to locate those responses using the same search mechanism.
All FAQs have been migrated to the NXP Community site. Several forum postings include references to FAQs and re-directs are in place to take you to their new location from those postings.
3 people found this helpful
    Outcomes
