56F84xx_Program_in_FLEXNVM
File uploaded by Derek Snell Employee on May 12, 2016Last modified by Diana Torres on Feb 28, 2017
Version 2Show Document
  • View in full screen mode
This project is an example of using the DSC CodeWarrior linker to place code
in a different area of memory.  In this case, the FlexNVM flash block is used.
The example uses three different methods in the linker command file to force
specific code to a different memory segment, see examples below.  For more
information on the linker syntax, see the manual installed with CodeWarrior
at \CW MCU v10.6.x\MCU\Help\PDF\MCU_DSC_Compiler.pdf
This project was developed for the TWR-56F8400 Tower development board, using
CodeWarrior for Microcontrollers v10.6.6.  The project was created using
Processor Expert, and blinks an LED using the PIT timer interrupt.
The linker command file is located at
\Project_Settings\Linker_Files\FLASH_SDM.cmd.Here are the key changes to the
project:
MEMORY {
        # Added .p_FlexNVM memory segment
        .p_FlexNVM(RWX) : ORIGIN = 0x00068000, LENGTH = 0x00004000
# Added .FlexNVM_Code memory section
.FlexNVM_Code :
  TI1_c.obj (.text) # Place whole source file in this section
  OBJECT (FPE_low_level_init, cpu_c.obj) # Place individual function in this section
  * (FlexNVM_code.text) # Place from section defined in source code, see main.c
} > .p_FlexNVM
and in main.c:
#pragma define_section FlexNVM_code "FlexNVM_code.text"  RX
#pragma section FlexNVM_code begin
void main(void)
  /* Write your code here */
#pragma section FlexNVM_code end
Outcomes
