FRDM-K82F FlexIO Camera Demo_
Document created by edk Employee on Mar 29, 2016Last modified by edk Employee on Jun 13, 2017
Version 8Show Document
  • View in full screen mode
One of the new features that can be found on the FRDM-K82F is the FlexIO header. It’s be specifically designed to interface with the very cost-efficient OV7670 camera, and uses 8 FlexIO lines to read data from the camera. By using the FlexIO feature, it makes it easy to connect a camera to a Kinetis MCU. A demo is included with Kinetis SDK 1.3 which streams the video data from the camera to a host computer over USB
The FlexIO is a highly configurable module found on select Kinetis devices which provides a wide range of functionality
• Emulation of a variety of serial/parallel communication protocols
• Flexible 16-bit timers with support for a variety of trigger, reset, enable and disable conditions
• Programmable logic blocks allowing the implementation of digital logic functions on-chip and configurable interaction of internal and external modules
• Programmable state machine for offloading basic system control functions from CPU
All with less overhead than software bit-banging, while allowing for more flexibility than dedicated IP.
One of many places to buy the OV7670 camera module
OV7670 Reference Manual
FlexIO Overview
FlexIO Training presented at FTF
