QorIQ Processors document list
Document created by lunminliang Employee on Mar 24, 2016
Version 1Show Document
  • View in full screen mode
For QorIQ Processors you could find documents from official website:
Submit Form
And below document list in this place:
SDK/DPAA/Networking:
Using QMAN Dedicated and Pool Channels in USDPAA and Linux Kernel
LS2085 NADK Based IPSEC Application Communicating with AIOP
DPAA Ethernet Interfaces Shared-MAC between two Linux Partitions under Hypervisor(Topaz)
IPv6+AES.docx
T1040 L2Switch Software Support
IPSec demo on T1040RDB
hv.dts
IPSec on Freescale Hypervisor (Topaz) and T1040 (T1042)
Rate limiting in DPAA
QorIQ QMan CEETM Implementation in USDPAA
Read T2080 XFI link status
Shared-MAC and MAC-less Implementation in DPAA Linux Kernel Driver
P2020RDB IPV4 forwarding performance test.pdf
Set up NAT on QorIQ RDB
Set up VLAN on QorIQ RDB
SDK/Virtualization:
FTF-DES-F1254_QorIQ Device Virtualization.pdf
Virtualization Solutions in Freescale Linux SDK(1)– Hypervisor(topaz)
Tools/Build/Debug:
FTF-DES-F1321-QorIQ-Debug.pptx
AMF-DES-T1053 - Open Source Tools Development Tools for ARM® Architectures .pptx
AMF-DES-T1052 - QorIQ DevTools for Layerscape Family Products Applications.pptx
AMF-SNT-T1045-Freeescale-Solutions-targeting-SDN-NFV-markets-with-ARM64-processors.pptx
Modify T2080 rev1.1 MEM_PLL_RAT w/ using QCVS4.1.1
Using external GNU toolchain with CodeWarrior for QorIQ LS series – ARMv7 ISA
QorIQ SDK build for T4240QDS - Beginner's guide
Introducing the Scenarios Tool
QorIQ Linux SDK 1.6 Working With Yocto
T4240QDS_Altivec_example_with_MEPL.zip
Building uboot/kernel/test-application out of Yocto
Changing RootFS in SDK 1.3.2
Adding a new Flash Device to Codewarrior 10.x
Building SDK 1.3.2
Boot/Board:
LS2085 u-boot Workflow
T2080PCIeRDB_SPI_reboot failure.pdf
How to Flash/Reflash U-Boot and Linux to a Freescale Digital Networking Board
System Boot from SD/MMC Card with SDK 1.6 images
Secure boot for Non-PBL Platform
Booting from QSPI on LS102xA
Firmware update for LS1-TWR
Switches on PSC9131RDB
Re-flashing the P3041DS
Deploying SDK 1.3.2
Solutions:
NEXCOM Introduces Appliance Based on Freescale QorIQ T4240 SoC and Aims for Gbps UTM Throughput
Others:
A quick demo setup to toggle hue bulb using LS1021A IoT host processor and MKW20 zigbee
QorIQ_Linux_kernel_GPIO_enable.pdf
Announcements
I2C NCSW Use Case
FTF-DES-F1253 Lunch and Learn: Expedite Your Product Development with Linux SDK Backport Technolog
Processors/Cores:
L1 D-Cache Flushing
Using CPC as SRAM
1 person found this helpful
    Outcomes
