Create free i.MX6 processor design using our online application
Document created by makarand Kapoor on Mar 8, 2016
Version 1Show Document
  • View in full screen mode
Hello i.MX6 Users,
We have created a innovative application wherein you can create a i.MX6 dual lite hardware design as per your customised requirement in a minute.
Creating a new design is super easy where you need to add the processor, peripheral requirements and the board input power input to the application.
With these input requirements the application will
1. Find peripheral , power, clock, reset and power sequencing components
2. Find processor pin mux options
3. Optimise the power, clocks
4. Generate the design and draw the schematic to be viewed online.
It is a powerful algorithm meant exclusively for high end processors like i.mx6.
You can generate any number of designs using our application hosted at www.circuit-tree.com. We will shortly be expanding our library and also add more form factors to support different hardware designs.
Let us know if you have any questions/concerns/feedback.
Circuit tree team
2 people found this helpful
    Outcomes
