Ultra-Low Power LPC54100 Test Drive
Document created by Lauren Percy Employee on Jan 4, 2016Last modified by edk on Apr 18, 2017
Version 6Show Document
  • View in full screen mode
The LPC54100 Series microcontrollers are designed from the ground up to deliver the industry’s best power efficiency for always-on sensor-processing applications. These highly efficient MCUs support ultra-low-power performance for sensor tasks such as listening, collection, aggregation of sensor data, and sensor fusion.
The LPC54102 Sensor Processing/Motion Solution includes everything you need to add motion and other sensor-based features to your applications. Using the ultra-low-power, dual-core LPC54102 microcontroller, it provides a scalable solution for a family of connected sensor-based products.
RECOMMENDED PRODUCTS
ProductDescription
LPC5410x MCUsSensor hub MCU
NTAG I2CConnected tag solution
LPC54102 Sensor Processing/Motion Solution (OM13078)Development boards & kits
LPCXpresso54102 Board (OM13077)Development boards & kits
RESOURCES
TitleType
LPC MCU ForumsDeveloper forum
    Outcomes
