Therapy Adherence Solution
Document created by Lauren Percy Employee on Dec 2, 2015Last modified by Martha Diana Torres Ramirez on Apr 18, 2017
Version 14Show Document
  • View in full screen mode
Take health into your own hands with an NFC enabled healthcare solution. Let the therapy adherence solution monitor your health progress and prescription usage. Never again exceed your daily dosage or skip a pill. The fully configurable sensors in pill blister packs will securely communicate over NFC to a smartphone app that can store and send health data to your healthcare provider - allowing them to modify your therapy to provide you with the best, most efficient solutions for your health.
FEATURES
  • Cortex M0+
  • NHS31XX powered battery
  • NFC antenna
  • NFC monitoring on command
  • Embedded RTC
  • Multiple sensing principles in blister packs
                  Resistive: NHS3152 up to 21 pills
                  Capacitive: NHS3153 up to 21 pills
                  GPIO: NHS3100 up to 36 pills
  • Ubiquitous readout via NFC
RECOMMENDED PRODUCTS
ProductDescription
NHS3153Healthcare IC
NHS3152Healthcare IC
NHS3100Temperature IC
RESOURCES
TitleType
Healthcare solution ICs
Web Page
    Outcomes
