NTAG I²C plus Explorer Kit
Document created by Lauren Percy Employee on Oct 26, 2015Last modified by Diana Torres on Apr 18, 2017
Version 9Show Document
  • View in full screen mode
NTAG I²C plus is designed to be the perfect enabler for NFC in home-automation and consumer applications, this feature-packed, next-generation connected NFC tag is the fastest, most BoM optimized way to add tap-and-go connectivity to just about any electronic device.
All in one kit: demonstrate all the capabilities of the latest NXP NFC connected tags NTAG I2C plus, evaluate all NTAG I2C plus features, develop your own applications
Value Propositions
Zero power configuration: only use the energy harvested from the RF field to power all components – no battery
Dynamic data exchange between NFC mobile phone and embedded System: retrieve data from the embedded System or push data from the NFC mobile phone to the embedded System
Simplest and lowest BOM solution to add NFC interaction to your embedded System
RECOMMENDED PRODUCTS
    Outcomes
