Garmin Fitness Band
Document created by Lauren Percy Employee on Oct 26, 2015Last modified by edk on Apr 18, 2017
Version 9Show Document
  • View in full screen mode
Upgrade the power of your workouts with a fitness monitor that tracks your daily progress while monitoring your heart rate, calories burned, and sleep quality. Synchronize your progress with Bluetooth communication to the Garmin Connect app that allows you to set goals and track your fitness. Enable running mode to track running routes and measure distance and average speed. Personalize your workouts with your favorite music accessible through Garmin Connect.cf-lg.jpg
FEATURES
Hardware
  • Low-power touch sensing interface
  • High precision ADC converter
  • Bluetooth enablement
  • Full-speed USB 2.0 On-the-Go (OTG) controller or a full-speed crystal-less USB 2.0 device controller
Software
  • Activity tracker
  • Heart rate monitor
  • Measurement of calories burned
  • Sleep monitor
  • Smart notifications
  • Garmin Connect app
RECOMMENDED PRODUCTS
ProductDescription
Kinetis KL2632bit Cortex-M0 based MCU running at 48MHz with up to 256K Flash delivers enough performance to run a Bluetooth SW stack for synchronization to smartphone and process sensing data.
RESOURCES
TitleType
Garmin Vivosmart
Web Page
Garmin ConnectWeb Page
    Outcomes
