Cold Chain Tracker Demo
Document created by Lauren Percy Employee on Oct 26, 2015Last modified by Adrian Puga Candelario on Aug 1, 2019
Version 12Show Document
  • View in full screen mode
QUALITY CONTROL OVER THE COMPLETE LOGISTIC CHAIN
  • THE QUALITY AND EFFICACY OF THE TEMPERATURE SENSITIVE PRODUCT CAN BE CONTROLLED AT THE POINT OF ADMINISTRATION
  • HISTORY IS LOGGED, ALLOWING IDENTIFICATION WHEN A COLD CHAIN EXCURSION OCCURRED
OTHER FEATURES
  • PRODUCT AUTHENTICITY CHECK
  • TRACEABILITY E.G. MANUFACTURING BATCH
  • CHECK AGAINST EXPIRY DATE
  • BIG DATA
  • COMMUNICATION CHANNEL  PHARMA COMPANY - PATIENT
FEATURES NHS3100
  • FLEXIBLE TEMPERATURE MONITOR
  • FULLY CONFIGURABLE WITH CORTEX M0+
  • CUSTOMERS CAN WRITE THEIR OWN FIRMWARE
  • FUNCTIONAL SECURITY IN FIRMWARE
EMBEDDED RTC
  • INTEGRATED ACCURATE TEMPERATURE SENSOR
  • EASY INTEGRATION INTO FINAL SOLUTION
  • NHS31XX PLUS BATTERY PLUS NFC ANTENNA
  • UBIQUITOUS READOUT VIA NFC
  • ABILITY TO START MONITORING VIA NFC COMMAND
RESOURCES
Healthcare solution ICs
NHS3100
    Outcomes
