Blood Pressure Monitor
Document created by Lauren Percy Employee on Oct 26, 2015Last modified by Adrian Puga Candelario on Aug 1, 2019
Version 10Show Document
  • View in full screen mode
and_bp.jpgBlood-pressure monitors help make precise diagnoses of patients who suffer from hypertension by implementing techniques such as oscillometric methods and Korotkoff's measurements. These devices measure mean arterial pressure (MAP) and use algorithms to derive systolic and diastolic values, then display readings on an LCD screen. Typical blood pressure monitors are driven by a low-power, 8-bit or 32-bit microcontroller (MCU) and incorporate a pressure sensor in either an arm or wrist cuff.
FEATURES
  • Simultaneous readout of systolic/diastolic pressure and pulse rate
  • Alerts the user of the presence of an irregular heart beat
  • Calculates and displays average blood pressure readings
  • Bluetooth Class 1 with 128bit encryption of data
RECOMMENDED PRODUCTS
ProductDescription
Kinetis K5xKinetis K5x Measurement Microcontrollers (MCUs)
RESOURCES
    Outcomes
