Smart Beacon Solution
Document created by Lauren Percy Employee on Oct 26, 2015Last modified by Diana Torres on Apr 18, 2017
Version 8Show Document
  • View in full screen mode
The demo shows the NXP Beacon implementation running on Kinetis KW40 Wireless SoC.
At the start-up the FRDM-KW40Z board starts sending advertisements packets each ~2 seconds and the BLE beacons are captured from the NXP Smartphone app that implements Bluetooth Beacons profile.
A Beacon is a non-connectable device that uses Bluetooth Smart technology to broadcast packets that include identifying information and each packet receives the name of Advertising Packet:
Enabling the next generation of proximity tags and indoor positioning.
Multiple use cases: localization, navigation information, indoor tracking, mobile marketing.
FEATURES
  • Ultra-low-power single-chip solution that enabled Bluetooth Smart/ Bluetooth Low Energy (BLE) v4.1
  • Integrated security modules such as AES-128 Accelerator (AESA) and True Random Number Generator (TRNG)
  • Fast encryption/decryption for network commissioning and transmissions of supported protocols
  • Integrated buck-boost DC/DC converter, supporting a wide range of operating voltages from 0.9 V to 4.2 V, significantly reducing the peak current in the receive mode down to 6.5 mA and transmit down to 8.4 mA.
RECOMMENDED PRODUCTS
ProductDescription
NXP KW40Z
is an ultra-low-power, highly integrated single-chip device that enables Bluetooth® Smart/Bluetooth® Low Energy (BLE) v4.1 and/or IEEE® 802.15.4-2011 RF connectivity for portable, extremely low-power and secure embedded systems.
KW40Z MCU
integrates security modules such as AES-128 Accelerator (AESA) and True Random Number Generator (TRNG) allowing a fast encryption/decryption for network commissioning and transmissions of supported protocols.
The KW40Z MCU integrates a buck-boost DC/DC converter, supporting a wide range of operating voltages from 0.9 V to 4.2 V, which significantly reduces the peak current in receive mode down to 6.5 mA and transmit down to 8.4 mA.
    Outcomes
