Pre-Evaluation Testing - 7layers
Document created by David Fix on Oct 20, 2015Last modified by David Fix on Nov 11, 2015
Version 3Show Document
  • View in full screen mode
  • Easily detect faults
  • Reduce development costs
  • Speed up market access
This Product Is Probably of Interest If You:
  • Developing a wireless product
  • Are close to beginning market access testing
  • Looking to ensure a product launch timeline
Service Description:
7layers runs a variety of Pre-Evaluation test programs for mobile phones and connected devices, which help manufacturers detect faults at an early stage of the product development process. Depending on the size and set-up of a manufacturer’s test facility, it may be possible to run such tests in-house. However company-owned test equipment often does not fulfill the strict requirements that apply to an accredited test laboratory such as 7layers – or you simply may not have all necessary test equipment available. Our reliable Pre-Evaluation test results, combined with expert analysis and support, can help speed up product development significantly. The 7layers Pre-Evaluation test programs concentrate on the most critical tests that have a strong tendency to fail in the final certification process, or they support you in making the right choice for example regarding a module or antenna you are planning to integrate.
    Outcomes
