Product Review - 7layers
Document created by David Fix on Oct 20, 2015Last modified by David Fix on Nov 11, 2015
Version 4Show Document
  • View in full screen mode
Product Review
  • Receive detailed findings about your device performance
  • Identify any common design mistakes for wireless products
  • Help select the right off the shelf antenna for your device
This Product Is Probably of Interest If You:
  • Developing a wireless product
  • Need additional RF expertise
  • Looking to maximize wireless device performance
Service Description:
This comprehensive package is designed for manufacturers that are looking for consulting throughout the entire design phase to ensure the best performance of the device. The service is the combination of three Packages, which are also available individually, a complete design review (Design Review Package), evaluation of the antenna integration (Antenna Integration Package), antenna characterization (Passive Antenna Testing Package) and some over the air (OTA) performance evaluation and radiated spurious emission (RSE) testing. Evaluating key performance parameters of your product and implementation of recommended changes will facilitate the readiness of your device for certification testing.
The service performed will include:
  • Complete design review by an Sr. RF Engineer, including review of 2D and 3D drawings, Schematics and Gerber files
  • Identification of any common design mistakes for wireless products
  • Evaluation of the antenna matching circuit transmission line impedance
  • Antenna characterization
  • Over the air (OTA) performance evaluation and radiated spurious emission (RSE) testing of your device in an accredited test environment
Deliverables:
  • Summary report detailing findings from design review, including any recommendations/concerns
  • Antenna characterization results including radiation pattern, efficiency, return loss and peak gain
  • RSE and OTA results including TRP and TIS mid channel on the critical frequencies
    Outcomes
