AMPL Smart Backpack
Document created by Lauren Percy Employee on Oct 17, 2015Last modified by Diana Torres on Apr 5, 2017
Version 9Show Document
  • View in full screen mode
Never worry about running out of power again. AMPL's SmartBackpack intelligent power management system and integrated SmartBattery charges phones, tablets, and other gadgets on-the-go through 7 USB outlets accessible inside every pocket. You can even charge laptops or other items you typically plug into the wall with an expansion battery and AC Inverter module.
SmartBackpack allows you to monitor your devices without opening a zipper. The AMPL mobile app displays real-time battery levels and allows you to adjust charging priorities. Plus, embedded smart sensors monitor power flows, weather conditions and alerts you if you forgot your bag.
Using Bluetooth® to communicate and configure the SmartBackpack from a mobile app, AMPL uses a FRDM-FXS-MULTI-B board attached directly to the FRDM-KL26Z and several additional sensors.
FEATURES
  • FRDM-FXS-MULTI-B
  • FRDM-KL26Z
  • Freescale Sensors
RESOURCES
RECOMMENDED PRODUCTS
ProductDescription
FRDM-FXS-MULTI-B
Make your projects more connected. Incorporate Bluetooth® into your embedded designs using this sensor expansion board for the MMA8652FC accelerometer, FXAS21000 gyroscope, MAG3110 3-axis magnetometer, MPL3115A2 pressure sensor, FXOS9700CQ 6-axis sensor and MMA9553L sensing platform.
    Outcomes
