Smart LED application based on GoKit and FRDM-KL02
Document created by Zhe Tian Employee on Sep 28, 2015
Version 1Show Document
  • View in full screen mode
As general introduction on thread https://community.freescale.com/docs/DOC-328302 , I did a smart LED application with GoKit and FRDM-KL02.
In this design, FRDM-KL02 will communicate with GoKit by WIFI, and control LED flash.
Code Structure
Code Basic Introduction
In this project structure, you need to do following items on code.
  • ü Add your functions, such as UART, LED, motor driver code.
  • ü Add function running functions in protocol.c
  • ü Add functions order in main loop.
You can find my main.c and protocol.c as attachment.
In this document, I would like to detail introduce function MessageHandle()
void MessageHandle(void)
                pro_headPart    tmp_headPart; //Common command package
                memset(&tmp_headPart, 0, sizeof(pro_headPart));
                if(get_one_package)
                                get_one_package = 0;
                                memcpy(&tmp_headPart, uart_buf, sizeof(pro_headPart));
                                //CRC error, send back error command
                                if(CheckSum(uart_buf, uart_Count) != uart_buf[uart_Count-1])
                                                SendErrorCmd(ERROR_CHECKSUM, tmp_headPart.sn);
                                                return ;
                                So, you can see that only get_one_package=1, we can receive frame completely.
                                switch(tmp_headPart.cmd)
                                                case       CMD_GET_MCU_INFO:
        CmdGetMcuInfo(tmp_headPart.sn);        break;
                                                case CMD_SEND_HEARTBEAT:
        SendCommonCmd(CMD_SEND_HEARTBEAT_ACK, tmp_headPart.sn);
        break;
                                                case CMD_REBOOT_MCU:
        SendCommonCmd(CMD_REBOOT_MCU_ACK, tmp_headPart.sn);
                                                case       CMD_SEND_MCU_P0:
        CmdSendMcuP0(uart_buf);
        break;
                                                case       CMD_REPORT_MODULE_STATUS:
        CmdReportModuleStatus(uart_buf);
        break;
                                                default:
        SendErrorCmd(ERROR_CMD, tmp_headPart.sn);
        break;
After that, you can do operations mentioned in thread https://community.freescale.com/docs/DOC-328302. You can see smart LED device and been found.
Outcomes
