Download and install SMAC & IEEE 802.15.4 software stacks for the MRB-KW01
Document created by Luis Antonio Burgos Lopez Employee on Sep 8, 2015Last modified by Luis Antonio Burgos Lopez Employee on Sep 8, 2015
Version 2Show Document
  • View in full screen mode
The SMAC & IEEE 802.15.4 protocol stacks are a KSDK add-on, therefore you need the installation of the KSDK 1.2 before installing these connectivity stacks.
Install the Kinetis SDK 1.2:
Software Development Kit for Kinetis MCUs|Freescale
After installing the KSDK 1.2, download the desired protocol stack.
The connectivity software for this platform can be found in the board webpage, in the downloads tab:
Modular Reference Boards for Kinetis KW0x|Freescale
The installation window will guide you through an easy way to install the software.
Luis Burgos.
    Outcomes
