Finding Your Stuff
Document created by Paul Kuhn Employee on Aug 22, 2012
Version 1Show Document
  • View in full screen mode
There are a number of ways to help you find people, places, and content in your community. Searching, browsing, filtering, tagging, sorting, and bookmarking help you keep track of and locate the things you need.
  • Search to find people, places, or content by typing what you’re searching for into the Search field in the upper right corner. Matching results appear in a box below the field as you type. If you have tagged content, enter the tags into the search field to quickly find that information. To refine your search results, click the View All Results link and select options from the Search page.
  • Browse people, places, and content to find things you may have seen before, or to discover things you may not yet know about. Click the Browse menu, and then choose options from the side and top menus on the Browse screen to narrow your options.
  • Filter people, places, or content by specific categories to find more targeted results. On your What Matters: Communications page, filter your Communications using the Filter dropdown menu. Filter selections in your Browse menu by entering words into the Type to filter by text field, or click the Filter by tag button, then enter tags or browse for more tags.
  • Tags make it easy for you and others to find content when searching. Add tags to the Tags field on documents, discussions, blogs, and polls to make them searchable. You can even add tags to your profile so people can find you more easily. To add tags to your status updates type a # before words you’d like to use as tags.
  • Sort allows you to view content in an order that is meaningful to you. On your What Matters: Activity page, you can sort your activity stream by clicking the All Followed, Matters Most, Status Updates Only, or Hidden links that appear under the Followed Activity and All Activity tabs. On your Browse menu, you can sort your results by clicking an option in the Sort by drop-down menu.
  • Bookmarks are links you create to specific pieces of content in your Jive community or to web sites on the Internet that you can quickly reference in your bookmarks menu. Bookmark content you view by clicking the Bookmark icon on the menu to the right of the content window, or bookmark web sites by clicking Create > Bookmark and entering information into the Create a bookmark pop-up box.
    Outcomes
