i.MX25 PDK Board Flashing NAND
ATK (Advanced Toolkit)
ATK is a Windows tool for programming the flash memory of i.MX boards. It can be downloaded here.
Using ATK
This section will describe the procedure to erase the flash memory and program the bootloader.
1. Assemble the PDK using the CPU board, the Personality board, and the Debug board.
2. Connect a USB cable between the PC and the i.MX25 PDK Personality board.
3. Some hardware configurations (switches) must be set for booting from UART/USB:
  On the debug board:
  Switch SW5 -> Off
  Switch SW6 -> Off
  Switch SW7 -> Off
  Switch SW8 -> Off
  Switch SW9 -> On
  Switch SW10 -> On
  On the personality board:
  Switch SW21 -> 11000000
  Switch SW22 -> 00000000
{{Note|On SW5 thourgh SW10, "1" means the keys selected towards the edge of the board.}
4. Run ATK (1.6 or above) going to Start -> Programs -> AdvancedToolKit -> AdvancedToolKit
  Set the options:
  i.MX CPU -> i.MX25_TO1.1
  Device memory -> DDR2;
  Custom Initial File -> (keep it unmarked)
  Communication Channel -> USB
5. Power up the i.MX25 PDK
6. Click on "Next"
7. Click on Flash Tools to erase, program or dump the the flash memory and click GO.
NAND Flash Erasing
1. Configure the Dip Switch of Personality Board:
Switch12345678
SW1OFFOFFOFFOFFN/AN/AN/AN/A
SW2ONOFFOFFONONOFFOFFOFF
2. Choose NAND model K9LAG08U8M
3. Continue the steps
Remember to select the checkbutton BBT (Back Block Table)
Commands to flash kernel and rootfs
fis init -f
load -r -b 0x100000 zImage -h <host IP address>
fis create -f 0x300000 kernel
load -r -b 0x100000 rootfs.jffs2 -h <host IP address>
fis create -f 0x800000 root
fis load kernel
exec -c "noinitrd console=ttymxc0 115200 root=/dev/mtdblock2 rw ip=dhcp rootfstype=jffs2"
Command to create rootfs.jffs2
mkfs.jffs2 -r rootfs -e 0x80000 -s 0x1000 -n -o rootfs.jffs2
タグ(2)
コメント
The images are not loading for me.
Are there any documents you can point me to for more infomration?
Sorry, Cheshire.  When we migrated the content from an earlier wiki site, some of the images were lost (permanently).  Rather than doing away with this page entirely, we posted it hoping that it is of some help without the images.
Grant
Thanks for modifying the post, but I am looking for one more detail to get Redboot onto the board.
  I believe I have a pre-compiled redboot image inside the provided Linux SDK: L2.6.31_09.12.00_SDK_SOURCE
I don't know the memory address to program it to using ATK.
According to "pdk2009_12_imx25_Linux_UG.pdf" redboot.bin should be located at zero address of NAND
(BBT is not checked), zImage - from 0x0030_0000 (BBT is checked)
Thanks!  I had downloaded the windows documentation bundle, but failed to download the linux documentation bundle!  I downloaded everything I thought I needed on the downloads page, but didn't get everything I needed from the documentation page for the imx25pdk.  Thanks for your help.
Yuri, thanks for sharing the information!
Good luck, Cheshire.
Thank you for the sharing, when I flash or erase the NAND flash using ATK, the drop-down menu only show NAND,not "NAND model K9LAG08U8M",
The nand flash part on my CPU board is K9LBG08U0D, with different page size, does it mean that the ATK tool not support the flash K9LBG08U0D?
There are two options for i.MX25 PDK :
- with Samsung K9LBG08U0D-PCB0, 4k page size ;
- with Samsung K9LAG08U0M-PCB0, 2k page size.
Both are supported by the ATK ; please double check if BBT
and BI Swap of the ATK is set correctly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1118345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-381649836%22%20id%3D%22toc-hId-1304247285%22%3E%3CSPAN%20style%3D%22font-size%3A%2020px%3B%20line-height%3A%201.5em%3B%22%3EATK(%E3%82%A2%E3%83%89%E3%83%90%E3%83%B3%E3%82%B9%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%83%E3%83%88)%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EATK%E3%81%AF%E3%80%81i.MX%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEWindows%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DIMX_ATK_TOOLKIT%26amp%3BappType%3Dfile2%26amp%3Blocation%3Dnull%26amp%3BDOWNLOAD_ID%3Dnull%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--724740049%22%20id%3D%22toc-hId-197857400%22%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-1762772784%22%20id%3D%22toc-hId--1609597063%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EATK%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--44681679%22%20id%3D%22toc-hId-877915770%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20CPU%20%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81Personality%20%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20Debug%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PDK%20%E3%82%92%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20PC%E3%81%A8i.MX25%20PDK%20Personality%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%20(%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81)%20%E3%81%AF%E3%80%81UART%20%2F%20USB%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW5-%26gt%3B%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW6%20-%26gt%3B%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW7%20-%26gt%3B%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW8%20-%26gt%3B%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW9-%26gt%3B%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW10%20-%26gt%3B%E3%82%AA%E3%83%B3%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%AA%E3%83%86%E3%82%A3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%3A%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20SW21%20-%26gt%3B%2011000000%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20SW22%20-%26gt%3B%2000000000%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%7B%7B%E3%83%8E%E3%83%BC%E3%83%88%7CSW5%20thourgh%20SW10%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8C1%E3%80%8D%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%AB%AF%E3%81%AB%E5%90%91%E3%81%8B%E3%81%A3%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%BC%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E4.%20ATK(1.6%E4%BB%A5%E9%99%8D)%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%5B%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%5D-%5B%26gt%3B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%5D-%5B%26gt%3B%20AdvancedToolKit%5D-%5B%26gt%3B%20AdvancedToolKit%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20i.MX%20CPU%20-%26gt%3B%20i.MX25_TO1.1%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%A1%E3%83%A2%E3%83%AA-%26gt%3BDDR2%3B%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E5%88%9D%E6%9C%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20-%26gt%3B%20(%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E5%A4%96%E3%81%97%E3%81%9F%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B)%3C%2FP%3E%3CP%3E%E9%80%9A%E4%BF%A1%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB-%26gt%3B%20USB%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E5.%20i.MX25%20PDK%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6.%20%E3%80%8C%E6%AC%A1%E3%81%B8%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E7.%20%5BFlash%20Tools%5D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B6%88%E5%8E%BB%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%80%81%5BGO%5D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-645879795%22%20id%3D%22toc-hId-1568477244%22%3E%3C%2FH4%3E%3CH4%20id%3D%22toc-hId--1161574668%22%20id%3D%22toc-hId--238977219%22%3E%3CSPAN%20class%3D%22mw-headline%22%3ENAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%B6%88%E5%8E%BB%3C%2FSPAN%3E%3C%2FH4%3E%3CH4%20id%3D%22toc-hId-1325938165%22%20id%3D%22toc-hId--2046431682%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CP%3E1.%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%AA%E3%83%86%E3%82%A3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%82%A3%E3%83%83%E3%83%97%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E1%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E2%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E3%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E4%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E5%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E6%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E7%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3ESW1%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3EN%2FA%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3EN%2FA%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3EN%2FA%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3EN%2FA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3ESW2%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%B3%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%B3%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%B3%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20black%3B%22%3E%E3%82%AA%E3%83%95%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20NAND%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99K9LAG08U8M%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E6%89%8B%E9%A0%86%E3%82%92%E7%B6%9A%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23ffffcc%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9C%E3%82%BF%E3%83%B3BBT(%E3%83%90%E3%83%83%E3%82%AF%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB)%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-614370483%22%20id%3D%22toc-hId-1536967932%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%20rootfs%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%3C%2FH1%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3Ef%E3%82%A4%E3%83%8B%E3%83%88-f%3C%2FP%3E%3CP%3Eload%20-r%20-b%200x100000%20zImage%20-h%3CHOST%20ip%3D%22%22%20address%3D%22%22%3E%3C%2FHOST%3E%3C%2FP%3E%3CP%3Efis%20create%20-f%200x300000%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FP%3E%3CP%3Eload%20-r%20-b%200x100000%20rootfs.jffs2%20-h%3CHOST%20ip%3D%22%22%20address%3D%22%22%3E%3C%2FHOST%3E%3C%2FP%3E%3CP%3Efis%20create%20-f%200x800000%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3Efis%20load%20kernel%3C%2FP%3E%3CP%3Eexec%20-c%20%22noinitrd%20console%3Dttymxc0%20115200%20root%3D%2Fdev%2Fmtdblock2%20rw%20ip%3Ddhcp%20rootfstype%3Djffs2%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CH1%20id%3D%22toc-hId--1193083980%22%20id%3D%22toc-hId--270486531%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1294428853%22%20id%3D%22toc-hId--2077940994%22%3E%3CSPAN%20class%3D%22mw-headline%22%3Erootfs.jffs2%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3Emkfs.jffs2%20-r%20rootfs%20-e%200x80000%20-s%200x1000%20-n%20-o%20rootfs.jffs2%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3Ei.MX25%20PDK%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE2%E3%81%A4%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E-%20Samsung%20K9LBG08U0D-PCB0%E3%80%814k%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E-%20Samsung%20K9LAG08U0M-PCB0%E3%80%812k%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82ATK%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82BBT%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CBR%20%2F%3E%20ATK%E3%81%AEBI%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81ATK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6NAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%83%80%E3%82%A6%E3%83%B3%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AB%E3%81%AFNAND%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%80%8CNAND%E3%83%A2%E3%83%87%E3%83%ABK9LAG08U8M%E3%80%8D%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ECPU%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEnand%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%83%A8%E5%88%86%E3%81%8CK9LBG08U0D%E3%81%A7%E3%80%81%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81ATK%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5K9LBG08U0D%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%A6%E3%83%BC%E3%83%AA%E3%81%95%E3%82%93%E3%80%81%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A0%91%E5%BC%B5%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%83%81%E3%82%A7%E3%82%B7%E3%83%A3%E3%83%BC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%AC%9D%EF%BC%81Windows%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%90%E3%83%B3%E3%83%89%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Linux%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%90%E3%83%B3%E3%83%89%E3%83%AB%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81imx25pdk%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8Cpdk2009_12_imx25_Linux_UG.pdf%E3%80%8D%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81redboot.bin%20NAND%E3%81%AE%E3%82%BC%E3%83%AD%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E(BBT%E3%81%AF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%81zImage%20-%200x0030_0000%E3%81%8B%E3%82%89(BBT%E3%81%8C%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Redboot%E3%82%92%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E8%BC%89%3C%2FSPAN%3E%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%82%E3%81%861%E3%81%A4%E8%A9%B3%E7%B4%B0%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BLinux%20SDK%E5%86%85%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AEredboot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3A%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DIMX25PDK%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20style%3D%22color%3A%20%23017bba%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23cccccc%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EL2.6.31_09.12.00_SDK_SOURCE%3C%2FA%3E%3C%2FP%3E%3CP%3EATK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%20%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E3%82%81%E3%82%93%E3%81%AD%E3%80%81%E3%83%81%E3%82%A7%E3%82%B7%E3%83%A3%E3%83%BC%E3%80%82%E4%BB%A5%E5%89%8D%E3%81%AE%20Wiki%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%8C%20(%E6%B0%B8%E4%B9%85%E3%81%AB)%20%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%BB%83%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AA%E3%81%97%E3%81%A7%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%B6%E3%81%88%E3%82%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX25%20PDK%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0NAND%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%BB%E5%83%8F%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%AB%E6%8C%87%E6%91%98%E3%81%A7%E3%81%8D%E3%82%8B%E6%96%87%E6%9B%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-30-2012 01:07 PM
更新者:
