Camera Mounts
Document created by GUO XIAOLI Employee on Jul 12, 2012Last modified by GUO XIAOLI Employee on Jul 13, 2012
Version 2Show Document
  • View in full screen mode
Option #1
Camera Mount Designed by Eli Hughes of WaveNumber LLC.
You can order these parts through Shapeway.com which 3D prints on demand. You can choose from all sorts of materials depending on how much you want to spend.
Camera Mount
Option #2
To attach the camera we found useful to prepare two metal L-shaped pieces made from aluminium. With the help of black plastic distance posts (already available in the kit) and these metal stands, you may freely change the position of the camera over the surface. You may use following files to cut the required shapes (drawing was made using the QCad program):
    Outcomes
