create queue template use c
Document created by 利中 舒 on Jun 1, 2015Last modified by Diana Torres on Feb 24, 2017
Version 2Show Document
  • View in full screen mode
* Queue.h
*  Created on: May 28, 2015
*      Author: ShuLizhong
#ifndef QUEUE_H_
#define QUEUE_H_
#ifdef _cplusplus
extern "C" {
#endif
/*If you want to change the queue type(QUEUE_TYPE) and queue max size(QUEUE_MAX_SIZE),
  you should define it at front of include queue.h file.
eg:
******in xxx.h file*****
code****
#define QUEUE_TYPE   Other type(unsigned int)
#define QUEUE_MAX_SIZE   Other size(100)
#include "qeue.h"
code****
#ifndef QUEUE_TYPE
#define QUEUE_TYPE unsigned char
#endif
#ifndef QUEUE_MAX_SIZE
#define QUEUE_MAX_SIZE 100
#endif
#define bool unsigned int
typedef enum {
  OK,
  FULL,
  EMPTY
}QUEUE_STATUS;
typedef struct {
  unsigned int tail;
  unsigned int head;
  unsigned int size;
  unsigned int length;
  QUEUE_TYPE data[QUEUE_MAX_SIZE];
}Queue_tag,*pQueue_tag;
__inline void InitQueue(pQueue_tag q)
  q->tail = q->head = q->size = 0;
  q->length = QUEUE_MAX_SIZE;
__inline  QUEUE_STATUS EnQueue(pQueue_tag q,QUEUE_TYPE data)
  if(q->size++ == QUEUE_MAX_SIZE)
  return FULL;
  q->data[q->tail] = data;
  q->tail = (q->tail+1) % QUEUE_MAX_SIZE;
  return OK;
__inline QUEUE_STATUS DeQueue(pQueue_tag q, QUEUE_TYPE *data)
  if(q->size-- == 0)
  return EMPTY;
  *data = q->data[q->head];
  q->head = (q->head+1) % QUEUE_MAX_SIZE;
  return OK;
__inline bool IsQueueEmpty(pQueue_tag q)
  return q->size == 0;
__inline bool IsQueueFull(pQueue_tag q)
  return q->size == QUEUE_MAX_SIZE;
__inline unsigned int GetQueueSize(pQueue_tag q)
  return q->size;
__inline unsigned int GetQueueLength(pQueue_tag  q)
  return q->length;
/*__inline unsigned int DeMoreBytesFromQueue(pQueue_tag q,QUEUE_TYPE *data,unsigned int len)
  unsigned int i = 0;
  len++;
  return 0;
#ifdef _cplusplus
#endif
#endif /* QUEUE_H_ */
    Outcomes
