LS1024A - Dual Core Cortex A9 Processor For Home Gateway and Consumer NAS Market
Document created by edk Employee on Dec 11, 2014Last modified by Diana Torres on Apr 18, 2017
Version 7Show Document
  • View in full screen mode
Features
  • Programmable Packet Forwarding Engine (PPFE). It does a lot of off-load (2G-bits of 64 Byte NAT packet processing) good for Home Gateway environment
  • For consumer NAS environment it can use the same engine for TCIP offload with great performance
  • The PPFE engine does the 2G-bits of throughput with 64 Byte packet processing without using barely any CPU load
  • The Crypto engine is available as well  working together with the PPFE
Featured NXP Products
Development Hardware Used
Block Diagram
    Outcomes
