Sensor Fusion Toolbox for Android Version 20141210B
File uploaded by Mike Stanley Employee on Dec 11, 2014Last modified by Diana Torres on Feb 28, 2017
Version 2Show Document
  • View in full screen mode
For those of you who do not have access to Google Play, here is the latest .apk file for the Android version of the Sensor Fusion Toolbox.  This version should trap problems which caused previously reported crashes.  There are no visible changes to the functionality.
IF you have access to Google Play, we recommend that you use that as your default installer, as you can automatically get updates.
