My board is imx6dl_sabreauto and I use android4.4.2 source!The system stop at "Freeing init memory", when the system boot.
I found the boot message no have follow message:
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.39 GiB
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
input: WM8962 Beep Generator as /devices/platform/imx-i2c.0/i2c-0/0-001a/input/input7
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 13336576 extends beyond EOD, truncated
asoc: wm8962 <-> imx-ssi.1 mapping ok
input: wm8962-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input8
input: wm8962-audio Headphone Jack as /devices/platform/soc-audio.5/sound/card0/input9
mmcblk0boot1: unknown partition table
Please help me!
Thank you!
We use sd4 connect to Inand
Hi, Talent
Did you able to fixed this issue?
It seems that your rootfs path is not correct.
Saurabh
