Working GPIO flash demo for FRDM-K22F
Document created by Jeff Verive on Oct 6, 2014
Version 1Show Document
  • View in full screen mode
The following (after the "- - - - - -" is debugged code for flashing Green, Red, and Blue LEDs on the FRDM-K22F module.
#include "fsl_device_registers.h"
#include "board.h"
static int i = 0;
int main(void)
  // LEDs are common-anode, with cathodes connected to port pins.
  // Therefore, logic high (1) turns them off, and logic low
  // (0) turns them on.
  short OFF = 1;
  short ON = 0;
     hardware_init();
     GPIO_DRV_SetPinDir(kGpioLED1, kGpioDigitalOutput); //Green LED
     GPIO_DRV_SetPinDir(kGpioLED2, kGpioDigitalOutput); //Red LED
     GPIO_DRV_SetPinDir(kGpioLED3, kGpioDigitalOutput); //Blue LED
     GPIO_DRV_WritePinOutput(kGpioLED1, OFF); //Green LED initially off
     GPIO_DRV_WritePinOutput(kGpioLED2, OFF); //Red LED initially off
     GPIO_DRV_WritePinOutput(kGpioLED3, OFF); //Blue LED initially off
     while (1)
          for (i = 0; i<0xFFFFFF; i++)
          GPIO_DRV_WritePinOutput(kGpioLED1, ON); //Green LED on
          GPIO_DRV_WritePinOutput(kGpioLED1, OFF); //Green LED off
          GPIO_DRV_WritePinOutput(kGpioLED2, ON); //Red LED on
          GPIO_DRV_WritePinOutput(kGpioLED2, OFF); //Red LED off
          GPIO_DRV_WritePinOutput(kGpioLED3, ON); //Blue LED on
          GPIO_DRV_WritePinOutput(kGpioLED3, OFF); //Blue LED off
     return 0;
    Outcomes
