QSGVideoNode for imx6 does not work!?
Document created by Allen Wang on Jul 3, 2014Last modified by Allen Wang on Sep 8, 2015
Version 2Show Document
  • View in full screen mode
When I use QMediaPlayer (Qt5.1.1) to play a FHD video, the CPU (imx6dl) usage turns very high and the output is not fluid and also has some frame drop.
I found a patch that claims to solve this problem (links below are taking about the same thing) :
adding zero-copy-QSGVideoNode for imx6 - Qt by Digia
After patch appliance and recompilation of Qt Library and program rebuild, the performance issue remains the same.
Does anybody know how to enable this property correctly? Have I missed some points or mandatory steps?
Any comment will be appreciated, thanks!
