Some of you might know Conrad for RC models and a broad range of electronic components. Now you can buy your Freedom board from them across Europe. Check out their online catalogue at Schnellstart mit dem Freescale Freedom Board FRDM-KL25Z Conrad FRDM-KL25Z im Conrad Online Shop | 12...
They have also created a small booklet to get you quick started on your preferred project.
As a reminder, this board is the standard board for the Freescale Cup once you add the shield connectors to it.
