Exercise 3: Toggle all 4 LEDs on the K60 Tower using the PIT0 as ROM version
Document created by peterurbanek on Mar 17, 2014
Version 1Show Document
  • View in full screen mode
To do:
Implement a program that lets the 4 LEDs on the Tower toggle all together using the PIT Interrupt.
This time, let the program run in the Flash.
* toggle period 0.5 s
* extract vector table and service routines in 'vector.c'
* Change the linker command file 'ldscript_flash'
* Take care of the 16 Byte security settings from $400-$410 in the Flash. Do not overwrite!!!
Hint: Use the 'arm_cm4.c and 'arm_cm4.h' from the freescale kinetis homepage, which include access functions for the NVIC.
For ease of use, these routines are included in the result file.
Result: TWR_K60_PIT0_Flash.zip
Outcomes
